MacBook Pro 2017 a1708 (with functional keys) Not powering on
I just got my new 1TB SSD replaced the old 128GB in my system.
Now the laptop won’t start anymore, even when returned the old one it won’t work either. There is no power at all!
I need help please the laptop is new!
Update (05/11/2019)
Update: i sent my MBP to Apple and they fixed the issue luckily at no cost since it is still under the one year warranty, received it today, and installed the new SSD successfully, i think i should have been more careful when disconnecting the battery, use only plastic tools, i might have shorted something by mistake. Now, everything works fine with the upgraded SSD. Always disconnected the battery first, i have seen posts online that says you don’t have to disconnect the battery for a hard drive replacement, don’t risk it!
Is dit een goede vraag?
2 opmerkingen
It's a bit more complicated than just pulling the battery properly.
You really need to make sure the system is fully powered down (not in sleep mode), and disable Auto Boot before you disconnect the battery.
But I'm happy you got a working system again!
door Dan
for this case simple SMC reset would most probably do the trick.
door Seff Ka
