No power going to hot water tank - Solved
Why would my hot water tank not be getting power
Is dit een goede vraag?
Use a multimeter and test the breaker box then the electrical wall outlet. If it is working, you probably have a loose or disconnected wire. Great care should be taken when looking or testing for it. I would unplug it and start testing for continuity of the input wires.
Was dit antwoord nuttig?
Thank you. It is wired right to the box
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 146
3 opmerkingen
Gas or electric? Make & model number?
door mayer
It is electric gsw I replaced the elements and thermostat but not getting power at all.
door Laura
Thank you had someone in today I had to replace the box
door Laura
