Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
3DS XL charging light turns on for a few seconds, then turns off
I have a 3DS XL that was given to me by a friend. For months it was working until one day I decided to turn it on, and it blacked out after a second. I thought maybe it was the battery, so I decided to charge. I left it for hours, came back, and it didn’t turn on again. The charging light would light up, then turn off after a few seconds. I thought maybe my battery was bad, so I bought a new one, and it still didn’t work. Is there any way I can fix it?
Is dit een goede vraag?
3 opmerkingen:
have you tried using a different charger. If not, it could be the power supply because maybe it doesn't even recognize that there is a battery. If that is the case you could have a bad power supply, and you may have to solder on a new one but I am just taking a guess.
door
and it could also be bad battery pins on the board.
door
You can try cleaning the pins with alcohol and see if that helps.
door
Voeg een opmerking toe
1 Antwoord
When you say the light goes off does that mean it stops charging or its just an issue with the light?
Was dit antwoord nuttig?
2 opmerkingen:
It stops charging
door
It the charger loos?
door
Voeg je antwoord toe
Sharon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 715
