Fan is making a rubbing noise
So when my xbox one is on, the fan sounds like its hitting something. Any ideas? Should i open it up and use compressed air can to get dust out?
Is dit een goede vraag?
These fans cannot be repaired and is most likely the bearings are failing. The fan will need to be replaced. You can either find an OEM fan or a compatible aftermarket fan and splice it in.
Was dit antwoord nuttig?
Try spraying some compressed air into the fan blades.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 163
1 Opmerking
Probably bearings, but compressed air is worth a try $$$ :-) . Just power off the device first!!! Also, be sure you do NOT spray the can with it in any position but upright, as cold co2 can be rough on electronics.
door Harold
