Ga door naar hoofdinhoud
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
150 Vragen Bekijk alle
Console is not turning on but has power to USB ports?
So my Xbox One x is not turning on. I'm pretty tech savvy and can't seem to find a problem. It still has power to the USB ports and the controller vibrates when I plug it up. I took a power supply out of a working Xbox One X and it will would not turn on. I tried hitting all the buttons, turning it on with controller and putting a disc in it(didn't take the disc) none of these things turned it on. Anyone ran into this and could give some input? Thanks!
Is dit een goede vraag?
Score 10
5 opmerkingen
As of July 14th (that I'm aware of) I am having the same problem. The USB ports are powered, but the power button does nothing.
door
28 october 2020, same problems.
door
One or many Mosfet chips may of blown on the mainboards power rails. You would need to know how to diagnose these and replace with professional heatstation. Check out NorthridgeFix or Andrew Paul on how this issue is fixed.
door
Just a note - the power rail mosfets on the Xbox one X that Aidan has mentioned are not replaceable, they're fixed onto the board using epoxy.
Please do not try to replace them.
door
Hi, I have the same problem. No power, but USB ports are working and can charge the controllers, etc. Does anybody found the solution for this problem ?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Im currently experiencing the same problem.. Power in the USB port n game not powering on..
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hopefully someone knows what is going on and can help us out. I'm dumbfounded at this point.
door
Having the same issue, but on the Xbox one s
Score 1
Voeg je antwoord toe
Travis Cox zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 1,761
