Ga door naar hoofdinhoud
Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
148 Vragen Bekijk alle
How does the 'hardware microphone disconnect' on clid close work?
Does anybody have an idea how the lid-close hardware microphone disconnect is physically implemented?
Is it a switch in the hinge that disconnects the audio cable? Is it a pin from the lid sensor that goes from high to low that then pulls the digitised audio signal to zero?
Ref: https://www.apple.com/mac/docs/Apple_T2_... (p.13)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I haven’t put my hands on the new Air but I doubt it will work much differently than other Macs. Lid closing causes a sensor in topcase being activated by a magnet in the lid, a pretty simple and efficient mechanism. When sensor is activated the system is instructed to change power state and go into sleep mode and in most modern machines, if I remember correctly, after 3 hours into hibernation mode. The change of power state implies that a set of power lines (all S0 lines used by the Pc up and running) are switched off and get no power from the system until the lid changes sensor state again. Hope this is the info you were looking for..
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Henk Poley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 119
