Ga door naar hoofdinhoud
Informatie en ondersteuning voor het repareren van geluidskaarten.
3 Vragen Bekijk alle
Annoying static noise on realtek integrated audio
This has been an ongoing issue. The problem got temorarily fixed when It automatically installed an nvidia sound driver along with my video card, however after rebooting the problem promptly returned. Here’s whats going on: https://www.youtube.com/watch?v=FbOHncQs...
Before any of you ask, Yes I’ve tried reinstalling the driver, Yes, I’ve tried disabling the realtek driver and it refused to use the nvidia one.
Is dit een goede vraag?
Commentaar:
Is nobody going to help?
door
When does this sound happen? Right after you power on your computer? Is it still there if you mute the sound with software? Does it ramp up according to your volume control? Does any other sound play, or is it only always noise?
door
Going to record and upload a video. It starts shortly after booting into windows then goes away when it starts shutting down. I am going to set the speakers to full volume in the video so you can hear it.
door
https://www.youtube.com/watch?v=QtaiHAHO...
Static starts at 0:28 mark
door
Did something change for this to start happening? Software install/update? Does any other sound play other than noise?
door
4 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @connor2003
good day
please list down your pc components, e.g. using laptop or desktop.....
if using desktop please list down the parts...
e.g. power supply, etc
sometimes this issues, can be due to some issues,
e.g.
OS issues,
Power supply not clean
soundcard issues
mainboard issues
grounding issues
try running for a long run with a linux live cd, and play some music for an extended time... are there any distortion?
Was dit antwoord nuttig?
Score 1
Commentaar:
Dell Inspiron 3847 with stock oem dell motheboard
Intel core I5-4460@ 3.20 ghz
8 gb ram
Sandisk SSD plus 240 gb
EVGA gtx 1050
EVGA 750 N1 750 watt power supply
The sound card is built into the botherboard
the power supply, ssd, ram, and graphics card are brand new.
door
Hi Connor
Suggest you to update bios and test run in a "live linux environment"
https://www.linuxliveusb.com/
http://www.knopper.net/knoppix/index-en....
door
How is that supposed to fix my sound issues? For security reasons, I am not going to do that.
door
I end up buying a dedicated or external sound card to avoid the static noise issues.
door
Voeg je antwoord toe
Connor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 438
