Will a Google Pixel C screen replacement fix a backlight issue?
I have a Google Pixel C tablet with a backlight issue. It appears to be a form of loose connection. I press the power button to unlock and the screen doesn't light up but if you shine a bright light onto the screen you can see the device is on and you can use the device just like if the back light was on.
If you then turn the screen off and then tap it before pressing the power button to wake up the screen, it works fine.
I see there is a guide for a screen replacement but will this fix a backlight issue?
Is dit een goede vraag?
