Ga door naar hoofdinhoud
Repair guides for the CTK-501 Standard Keyboard made by Casio International in 1997.
4 Vragen Bekijk alle
Is my Casio Keboard broken? or just the DC Power Supply?
So my Casio CT-600 Keyboard runs a DC 9V Powersupply. My friend accidentally connected it to a 220V Outlet (My keyboard needs only a 110V btw, so it has its own transformer.) After that the Keyboard didn’t work. I was planning to buy a replacement for my DC Power Supply, but before I do, I really need to know what’s broken. Can anyone please answer, I would really appriciate it. Thank you!
Is dit een goede vraag?
1 Opmerking
I did the same but not only 110v adapter burnt but also the keyboard doesn't work after that. It turns on. LCD display comes on but no sound. Also can't turn it off. Have to pull out the jack from behind the keyboard. On/off switch on keyboard just turns it on. Not off.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi XenoSov
to clarify … your friend plug the 110V range adapter into 230V outlet and power it on ?
if so ….most prob the adapter has been blown, but i guess the keyboard should be fine.
well, either to purchase a replacement power supply adapter, from casio, which i recommend.
else, if you want to try…. you can open up the defective adapter and try repairing it.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
i just bought a new casio plug and my casio keyboard still won’t work without batteries
door
So how do I open it to repair the connection to the adaptor?
door
Voeg je antwoord toe
XenoSov zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,737
