LG Dishwasher lights “fritzing” when on, making iradic noises
Our LG dishwasher- Inverter Direct Drive- recently started having its control panels lights flickering/fritzing when turned on, will make iradic beeping noises and will do this when the dishwasher is running. The dishwasher turns off mid cycle when this happens as well
Update (03/30/2019)
Thanks for the response! I’ve taken off the front door and the control panel- I’ve don’t see what looks like a control board
. The front control panel doesn’t seem to have anything significant standing out to me as damage
Is dit een goede vraag?
21 opmerkingen
Hi,
What is the model number of the dishwasher?
Try switching off and totally disconnecting the power from the dishwasher for about 5 minutes and then reconnecting the power to check if has been reset back to normal operation.
door jayeff
Hi- it’s a an LG LDF5545ST. I’ve already reset it several times by disconnecting it from the power.
door Breata Jessen
Breata Jessen any chance you can post some close ups of the board in the second picture?
door oldturkey03
I have tried to get LG to send me a replacement board even under warranty and they refused unless i paid a technician to do it . I have a masters in Mechanical engineering and they wouldnt do it. time to switch brands.
door Sunny D
This happened to me. They cover the warranty of the part but not the tech. But won't send the part without a tech diagnosis. Stupid. I unscrewed the top panel and it was a loose wire. Problem solved. No new panel needed.
door Megan Arner
16 commentaren meer tonen
