lg watch replacement band
is their any way to replace the bands on a lg watch sport even thought the watches bands are packed full of NFC antennas and many more things needed for it to function properly one is broke and im not sure where to get a replacement piece
Is dit een goede vraag?
4 opmerkingen
model is w280A
door Dan
Hi, I think the only way to get it is from here:
https://globaldirectparts.com/oem-lg-wat...
You have to buy both straps separately.
And yes, it's easy to replace them: Just remove the two screws on the sides of the strapholder and gently pull out the straps, by pressing them also slightly towards the backside of the watch. Like this you're able to click out the two bands, which have connectors towards the watch itself.
The new straps can be attached in the same way again... Good luck! (Have to replace mine too, as they have been proken both together now after only 2 years of usage! Crappy design... The next watch is for sure not a LG watch anymore...
door Simon
There is a website that sells the bands for $35 per side but they are on back order.
I found a guy on ebay that sells refurbished ones that he makes with a 3d printer for $70 for both sides shipped.
https://www.ebay.com/itm/LG-Watch-Sports...
door seige332
Then I found another guy that sells replacement bands on ebay without the antennas, so you have to remove the antennas from your origianl band and slide them into the replacement for $21 for both sides shipped.
https://www.ebay.com/itm/Lg-sport-watch-...
door seige332
