Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
642 Vragen Bekijk alle
Why won't some of my screws undo?
Hello! I am currently replacing the screen of my iPhone SE and for some reason some of the screws wont undo. The phone is a month old and is from the mobile provider EE here at England but I am replacing the screen as it is water damaged. Some of the phillips #000 screws just won’t undo on the inside. For example, one of the screws for the battery connector shield bracket will undo but the other will not! I have tried using cheap phillips #000 drivers, the free one that has came with the screen and also some more high end ones and nothing seems to do the job!
Thanks,
Rafay.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Nu winkelen
iPhone X Fix Kits
Nu winkelen
3 Antwoorden
Gekozen oplossing
Here’s the definitive iFixit guide on removing screws:
How to Remove a Stripped Screw
Here’s the video on removing stripped screws:
https://www.youtube.com/watch?v=SEZyUzt8...
Was dit antwoord nuttig?
Score 3
Commentaar:
Thank you. I will try these methods.
door
Just try replacing it properly and unscrew it. you can also put a small piece of rubber on the top of the screw if it is really tight.
Score 1
Commentaar:
Hello. Thank you for your response. I have tried the rubber band trick and the toothpaste trick, etc but those screws just wont undo.
door
Is it stripped? Apple puts some glue on there screws so thy stay in well there isn’t much to help, a lot of it is about your grip. Do you have the ifixit took kit? It gives you a good grip so your able to open it. Try applying a little heat so it loosens up.
Good luck.
Score 1
Commentaar:
Thank you! I do not think it is stripped as although it is not a cross shape, it is not deformed. I will try applying heat and if not I will try glue. Thank you for your help! I will let you know how I get on later on as I am currently very busy with studying. I also do not have the ifixit kit. I will get their phillips 000 screwdriver as I think that having a high quality screwdriver will fix my issue.
door
Voeg je antwoord toe
Rafay Siddiqui zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 44
