Ga door naar hoofdinhoud
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
30 Vragen Bekijk alle
Can I use the display unit of the Surface pro 5 for pro 6?
Hi,
can i use the Display of the pro 5 to fix my shattered Pro 6 Display?
Is dit een goede vraag?
Score 2
1 Opmerking:
I'm going to give a tentative "yes" with the caveat that I'm not speaking from direct experience.
Looking at pictures of replacement screens for both the Pro 5 and Pro 6, the cabling looks to be identical. The specs (resolution, physical dimensions, etc) for the screens are also the same. I also found part number "LP123WQ1 SP A1" being sold on eBay as a replacement screen for the Surface Pro 6 *AND* the Surface Pro 5.
door
Voeg een opmerking toe
1 Antwoord
No you can’t, the Surface Pro 5 and Pro 6 displays have different touch controllers and are not cross-compatible.
Was dit antwoord nuttig?
1 Opmerking:
I have installed the pro 5 display on a surface pro 6 without issues. I’m not sure sure where you got your info from but they are 100% cross compatible.
door
Voeg je antwoord toe
ykf kaanf zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,661
