Ga door naar hoofdinhoud
The 8.9" version of Amazon's new high-end tablet series, released in November, 2013.
Kindle fire HDX screen jumps around by itself.
My 3rd generation Kindle with cellular started “jumping” from screen to screen all by itself ( from home pg to settings, runs though all the options in settings, then to guide, then to….)
I have reset, and factory reset a number of times. The techs in India were no help; they just had me do everything I have already tried. The last attempt with them, one of them said the device was “not fulfilled” and that was the problem. After asking him 3 times what “not fulfilled” meant and not getting an answer; I stopped that waste of time. I keep getting told it’s a software problem but I have updated and reset numerous times. I think it’s a hardware issue. Any ideas?
Is dit een goede vraag?
Score 3
2 opmerkingen
there are two different screens, a 71 pin and a 90. How do I know which one I have before ordering a replacement?
door
You are correct. Get the model number and just comment it, and I'll find it for you .
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s a hardware issue. It’s called ghost touch which is when the screen on your device jumps around, fights against your touch and plain out annoying. To fix ghost touch you need to replace your screen, because something is damaged in the digitizer. Digitizer is what senses your touch to allow you to swipe and move things around.
The fix tutorial can be found here: https://www.youtube.com/watch?v=g6e5-H_U...
You need to watch from 0:10-3:00 to remove the screen successfully and then just reverse the steps you took to put it back together.
Replacement part can be found here: Kindle Fire HDX 8.9" (3rd Gen APOLLO, 71-pin Edition) Screen
Replace a front glass digitizer screen compatible with the 3rd generation APOLLO model Kindle Fire HDX 8.9". Features a 2560 x 1600 LCD display. Afbeelding
Product
$99.99
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
wrong. it is software and calibration helps. do not open the tab and heat it up, that is absurd. i activated dev mode set touch and pointer and the amazon touch sound (which was real useless as it did not make noise on desktop touching only nav bar touching) i put google play on and got a touch screen calibration app to help. now no ghost touch for a half hour.
door
How do I set up the calibration? Could you please give me more details as I'm experiencing the same issue. Thanks a lot.
door
I’m also having this problem, but my Kindle isn’t a Fire.
door
Wow!!!!! Thank you all
door
Voeg je antwoord toe
sudiki zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 140
Altijd: 17,442
