Ga door naar hoofdinhoud
Repair guides, troubleshooting information, and service help for refrigerators manufactured by General Electric (GE).
221 Vragen Bekijk alle
Antique GE Fridge cool, but not cold, running a lot.
I have an old (maybe 1950’s) GE model LB 81SC.
It’s a small fridge that I just want to keep drinks in the garage in. It worked fine when i bought it, but later seemed to struggle to stay cold. I moved and didn’t use it for a year and thought i would plug it in again recently.
It runs a lot, and the evaporator in the small freezer section gets cold, at first it dropped into the 20’s, but now it’s got water drops on it that aren’t frozen. It has no fans either for condenser or evaporator. The condenser on the back is clean. The compressor gets hot, but the heat doesn’t seem to travel very far into the condenser, i don’t know how warm the condenser is.
The thermostat seems to work, it kicks on when i turn it to colder anyhow.
It’s staying in the low 40’s in there most of the time, but now the freezer section isn’t frozen either and i’m feeling like it’s running nearly constantly. It should really stay in the 30’s.
How do I go about troubleshooting an old simple unit like this?
thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here’s the the list to run through:
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 3
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Cause 4
Start Relay
The start relay works in conjunction with the start winding to start the compressor. If the start relay is defective, the compressor may sometimes fail to run or may not run at all. As a result, the refrigerator will not be cold enough. To determine if the start relay is defective, use a multimeter to test it for continuity between the run and start terminal sockets. If the start relay does not have continuity between the run and start terminal sockets, replace it. In addition, if the start relay has a burnt odor, replace it.
Cause 5
Temperature Control Thermostat
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may prevent the refrigerant system from running. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
Cause 6
Temperature Control Board
The temperature control board provides voltage to the compressor and fan motors. If the temperature control board is defective, it will stop sending voltage to the cooling system. However, this is not a common occurrence. Control boards are often misdiagnosed—before replacing the control board, first test all of the more commonly defective components. If none of the other components are defective, consider replacing the temperature control board.
Cause 7
Start Capacitor
The start capacitor provides a boost of power to the compressor during start-up. If the start capacitor isn’t working, the compressor may not start. As a result, the refrigerator will not cool. To determine if the start capacitor is defective, test it with a multimeter. If the start capacitor is defective, replace it.
Cause 8
Thermistor
The thermistor monitors the refrigerator temperature and sends the temperature reading to the control board. The control board regulates power to the compressor and evaporator fan based on the thermistor readings. If the thermistor is defective, the compressor and evaporator fan may not run when necessary. As a result, the refrigerator will not be cold enough. To determine if the thermistor is defective, test it with a multimeter. The thermistor resistance should change in conjunction with the refrigerator temperature. If the thermistor resistance does not change, or the thermistor does not have continuity, replace the thermistor.
Cause 9
Compressor
The compressor is a pump which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. If the compressor is not working, the refrigerator won’t cool. However, this is rarely the case. Before replacing the compressor, first check all of the more commonly defective parts. If you have determined that all of the other components are working properly, check the compressor. Use a multimeter to test the continuity between the electrical pins on the side of the compressor. If there is an open circuit, the compressor is likely defective. If the compressor is defective, it must be replaced by a licensed technician.
Cause 10
Main Control Board
The main control board might be defective. However, this is almost never the cause. Before replacing the main control board, test all of more commonly defective parts. If none of the other components are defective, consider replacing the main control board.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
So it seems like I can check all those boxes except maybe compressor. It starts up and runs when triggered, could it be weak but still partially good? Condenser is clean, no fans to go bad, and the compressor kicks on and off...
door
Hi,
Check if the door seals are still OK.
Place a sheet of paper between the door and the cabinet and try to pull it out with the door closed. It should pull out with a bit of effort but it shouldn't pull out that easily or even just fall out ;-)
Do this at various points all around the door (hinge side as well as the bottom)
If the compressor is running nearly all the time but the evap unit is not getting cold then there may be a problem with the sealed system e.g. loss of refrigerant due to a leak, a blockage in the sealed system or a faulty compressor.
Depending on your location you might need a licensed refrigerator repairer to check if the sealed system is OK or not.
Not only because it may be a legal requirement to do so (prevention of release of refrigerant gases into the atmosphere) but they also have the necessary equipment that can test the refrigerant pressures etc. in the system (high pressure side/low pressure side) to determine where the problem may be. Unless your fridge has pressure test connections to the sealed system, it will have to be "cut" into to connect to it to check the pressures. Again a specialized task
door
jayeff the cost of a tech to check it would probably far exceed the value of the box.
door
Hi @mayer ,
Agreed but "antiques" may come back in value if it is in good condition and it works.
Bit worried that the new refrigerants may not be suitable for an old fridge though if it is a lack of refrigerant. ;-)
door
Voeg je antwoord toe
Samuel Stanton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 5,366
