Ga door naar hoofdinhoud
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
What kind of switch is the on/off button
I have broken on/off switch what kind is it? SPST, Normally Open, or what? I see the two little wires that come from the back of the switch, Just wanted to replace it with common stock items.
Thanks in advance.
Is dit een goede vraag?
1 Opmerking
Thank you, I thought it was a NO, but since it had broken off, It would come on as if power had been out and had then been restored.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s a simple push-button under spring pressure normally open.
If you can find the Bottom Housing Apple P/N 076-1210 it comes with the button.
Here’s one source Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s only $5.00 How can you go wrong!
If you live in the UK or EU Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s a bit more $25.00 ;-{ Maybe you can haggle a bit.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I have several SPST and a handful of NO's regular round red push button types, so I have one for free.
door
You need a momentary contact switch (push button with spring) not a SPST
door
Voeg je antwoord toe
Michael Inman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 377
