Ga door naar hoofdinhoud
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52 Vragen Bekijk alle
Stuck! Car still won’t turn over after new fuel pump and power checks
Hi. I have a 2000 Honda Civic. One day I drove the car about 140 miles then get home fine and went to turn on car about an hour later and it wouldn’t turn over. Used starter fluid and car wanted to start when sprayed. Replaced the fuel pump with a new car quest pump but still didn’t work. Checked the grounds around the engine. Checked power to pump relay which was good and it clicks. Checked power to the fuel pump which was good. Replaced fuses for ignition coil and a few others. Still same thing it doesn’t want to turn over. It cranks but nothing more! Any help I’m stuck??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Combustion engine need air, fuel and a spark to turn over. If using starter fluid almost gets the engine to run then it seems a problem with fuel flow. Since you replaced the fuel pump then check the fuel filter as well as the fuel line for obstructions.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jeremy Levine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 201
