Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Reboot when i'm calling
When the dock connector is connected, it will restart.
I changed the dock connetor, but it not good.
What is the problem? :S
Is dit een goede vraag?
3 opmerkingen
I may have a problem with the battery. (Really doubt that it’s the battery) it probably needs logicboard repair.
door
It sounds like you either need a replacement earpiece speaker or top components flex cable replaced. If the earpiece is not connected properly, any time it attempts to make sound through that speaker, it restarts the device. Should be as easy as top flex cable and earpiece replacement.
door
There have been a lot of problems with the dock connectors. Does it do that with a regular iPhone charger?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Front camera cable must have been ripped, this would be a fault caused by the proximity sensor somehow being damaged. See if it reboots with front camera disconnected.
Siri also uses proximity sensor so see if it reboots when you try to run Siri.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ttdarabant zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 211
