No success after replacing battery, what next?
Hi I dropped my iPhone and there is a small crack in the screen and on the back case.
The screen didn't break and the phone was still working but it stopped charging and wasn't recognised by the computer.
Eventually the battery died and the phone hasn't turned on since.
I have replaced the battery with a brand new one, what I wanted to ask is:
Neither batteries will charge, I assume that there both carry a charge, albeit a small amount to power the device so is this a logic board issue? or the dock connector?
Is dit een goede vraag?
2 opmerkingen
okay, I will replace the dock connector next guys, thanks.
Surely the new battery I bought contained enough charge so I am curious as to why it wont switch on - even with a faulty dock connector?
(update) iPhone is able to power on from USB plug into the wall, but reboots after two minutes, and switches off when unplugged.
door no way
it should have..if all your connections are correct and there was no other damage. use a multimeter to measure the charge in your batteries..
door pollytintop
