Random black screen...AHT shows 4MOT/40000003: HDD-1333
Have been experiencing random black screen upon waking the computer up from a longer period of sleep 10-12 hours. Screen initially lights and then goes black. Thought it may be the GPU (AMD Radeon 6970M 2gb) so ran the AHT to see if it came back with anything on it but instead got 4MOT/40000003: HDD-1333. From what I've found online this seems to be the hard drive fan behind the motherboard. This imac was special ordered with two drives, SSD with the OS on it and then a secondary HDD. Do you think replacing the fan will fix the black screen issue? Is there a fan for each hard drive in the computer or are they stacked in the same location? Thoughts on what this may be and possible fixes?
Is dit een goede vraag?
3 opmerkingen
Have you changed a hard drive?
door mayer
Nope. Factory SSD and HDD.
door Nick
Part of the problem is I'm not sure which drive would need replaced if one does, since there's two and AHT doesn't tell you much along those lines....
door Nick
