Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Vragen Bekijk alle
Replacement dock connector for iPod touch 4G?
I have an ipod touch 4G and all the pins on the dock connector on it have either been bent or missing. I wish to replace it but i'm strugguling to find any guides. Does it require soldering or something?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Hey Guys, just see here you can solve your Ipod Touch dock port problem.
http://ifixor.wordpress.com/2013/01/01/a...
Was dit antwoord nuttig?
Lots of soldering. Two anchors and then it looks like each of those bent pins you mention have a corresponding solder joint.
I have replaced the dock connector on the 2nd, 3rd and 4th Gen touch. I can help. Let me know if you're interested. It's a very difficult process especially on the 4th that requires special soldering equipment and a microscope.
1 Opmerking:
Yes I wish to know how to do and help would be much appreciated thanks.
door
Well, you first have to find a replacement dock connector. I order them directly from China on eBay. To remove, you need to disassemble the iPod completely then remove the solder from the two anchors of the dock connector with desoldering braid. I then use a hot air soldering gun to heat up all the pins at once and remove the old connector. I then install the new connector in reverse. It is a delicate process requiring plenty of patience.
I know this is iFixit and not an advertising agency, but here is the best solution I have come up with. I had the same problem, and ended up sending it here. http://www.iresq.com/ipod-repair/ipod-to...
Fixed it!
Voeg je antwoord toe
Iraneus De Almeida zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 18,439
