So I was going to go all out and make some amazing additions with arduino but I was reluctant to drill into this vintage beauty. I wanted a solution that was not destructive in any way and could be reversed if wanted.
I found a $3 clip on bicycle light and took the guts out.
This gave me a circuit board, and two LEDs powered by 2 watch batteries.
I attached that to the underside with a small piece of double sided tape.
I extended one light up through the rivet hole in the bottom with some additional wire. Also I replaced that LED with a blue one for obvious reasons. I left the bottom white LED in the position it came in for a ground FX look.
The tube is wrapped in electrical tape at its base to wedged it in where the AA batteries were stored.
Now with one press on the bottom button it turns on with a steady blue, second press is a fast flash, third press is a slower flash and the fourth press turns it off.
This has been a great fix for me and I hope it can be helpful to others out there.
Let me know if there are any other questions about this process.
Best,
-J
5 opmerkingen
Does it do anything at all?
door mayer
No it doesn't :(
I tried to run leads right to the light bulb too. No dice.
door James Dargie
if you remove the screws. (second pic).. does it come out?
you might need to try to wriggle
i believe it is a 3V Flashlight bulb which you can consider changing to LED type.
door Augustine
The one screw is just to fasten the conductor latch in place. I have removed it and nothing else comes loose. There is a squarish notch next to the bulb hole so this might be some clue. Although I am at a loss.
There’s nothing to “wriggle” really. I can’t grab the bulb enough to do anything. It does look screwed in, though.
door James Dargie
Hi @dargie ,
To my view, in the second picture it seems as though the connector which is riveted in place is connected to a piece which extends under the plastic to make contact with the outer screw section of the bulb and the connector that is held in with the screw is pushed down to make contact with the centre conductor of the bulb.
When the device is closed then both connectors are in contact with the power but only one needs to be is pushed down far enough to make contact as the other is already in contact.
Perhaps you need to drill out the rivet to release the "hold" that the connector has on the bulb or maybe that's what the bulb "screws" into and you have to come in from the top.
The grey plastic section above the bulb may be 'reversed thread" onto the clear plastic. Have you tried unscrewing it in the opposite direction to the normal way of unscrewing things?
Can you test with an Ohmmeter across the bulb or even the two connectors, the screwed in one pushed down to make contact with the bulb, to check if there is continuity through the bulb?
Also just for interest, if you have an Ohmmeter, check for continuity between the two rivet heads on view in the 2nd picture - the one on the connector and the one slightly to its right as viewed in the picture.
Just my 2 cents ;-)
door jayeff
