Ga door naar hoofdinhoud
A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
15 Vragen Bekijk alle
My laptop won't switch on, why?
When I plug my charger in the light of caps lock flashes and the light showing it's charging is also on but pressing the power does not result in my laptop switching on. Does anyone have a clue what's the problem and how to sort it out?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Try the following.
  • Remove the battery and press the power button for 30 seconds
  • With the battery removed, plug in the charging cable and check if you can boot
If that doesn’t work, your battery is dead.
Was dit antwoord nuttig?
2 opmerkingen:
Didnt work. Battery probably is dead
door
You might be able to find a new battery if you search the partnumber of it on Google. Usually the partnumber is located on a sticker on the battery,
door
Voeg je antwoord toe
Hamza ahmad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 75
