Ga door naar hoofdinhoud
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
How can I remove this stripped screw?
I was trying to exchange my left analog stick, which was starting to have that 'ghost input' issue. However, I just can't get that screw off! I bought a second hand device, so i guess the pre-owner has done this. I tried using a rubber band, but it failed. Any other solutions plz? Will it be ok to use wd40 on it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Do not use WD40. It may damaging the surrounding parts. That screw does not seem to be stripped though, so try using different screwdriver sizes and more force than you usually would.
Was dit antwoord nuttig?
Voeg je antwoord toe
Pizzaguy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 388
