Ga door naar hoofdinhoud
The Kenmore Model Number 970-678431 is an inductive cook-top range with single door oven and warming-drawer.
12 Vragen Bekijk alle
Dimmed Frigidaire stove electronic display
( right model Frigidaire BFEF374A )
I bought this used stove and the digits on the digital display are barely visible. I sought a solution and found that cleaning contacts or changing the capacitors might solve the issue. Contacts of the display are welded in the unit’s board but I changed the capacitors and it is still the same.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Possibly a cold solder joint on the control board. Reflow it it with a cheap soldering iron.
That failing, replace it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Mayer, I will revisit this option. I admit I did not check if all the solder joints were still intact.
door
Voeg je antwoord toe
Bob Harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 234
