Ga door naar hoofdinhoud
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1273 Vragen Bekijk alle
Toshiba S855D-S5120 won't power on
I have tried the typical power cycle solution where you disconnect power adapter, battery, discharge power, reconnect and power-up. I get nothing. No light indicators, nothing. I then bought a new power adapter and that didn’t help. I then replaced the female power connector that the power adapter plugs into…because it felt loose when plugged in. That also did not help.
I just have no power. Period.
Any help/ideas is appreciated.
Is dit een goede vraag?
2 opmerkingen
do you think you'r battery is dead?
door
I have tried bypassing the battery with just the power adapter too. Nothing.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try the following:
Open up and try reseating RAM.
Try one RAM at a time in both sockets.
Instructions on opening:
http://www.irisvista.com/tech/laptops/To...
Take out CMOS battery and leave overnight.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I did what you suggested. Now I am just waiting with the CMOS battery out. Out of curiosity, what is this supposed to do?
door
Just to force CMOS to reset to default. Safer than shorting.
If that doesn't work I would say it is motherboard replace time or it is toast.
door
Voeg je antwoord toe
Jerad Kays zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 127
