Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
70 Vragen Bekijk alle
Replaced the screen and it won't stay attached
I had a friend do the replacement and a corner of the screen came up. Heated and clamped it but now the whole right side of the screen won’t stay attached. Dust and garbage are getting inside and it won’t stay closed no matter what I do.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
What type of adhesive did your friend use? I use tesa tape whenever I repair phones that don’t come with preinstalled adhesive.
Unfortunately, with the dust getting in, the corner won’t go back down unless you use a dab of glass safe super glue. Get a bottle that has a small tip to get in between the glass. Make sure you don’t apply too much.
I usually don’t suggest super glue, but the screen on the Pixel is pretty hard to get up without damaging the screen. Ideally, you’d want to remove the screen and reapply tesa tape.
Was dit antwoord nuttig?
Voeg je antwoord toe
Anthony Footit zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 62
