Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Vraag afgerond
touch screen won't work after using phone for a while
Hi,
I started this thread a few days ago, but now i'm sure what the problem is.
When I use my iphone, the touch screen suddenly stops working. Mostly after a restart, or when iphone locks after a minute of doing nothing.
If i restore the iphone it works back normal, but after a while it stops back from working.
I tried restoring for a billion times, with the original os, i tried several times with a custom os (jailbroken one),
And it's always the same. (both were ios 4.2.1)
Probably there is something wrong on the logic board i think.
I tried 2 different screens, both same result.
Can i reset the phone on a more effective way than a restore with iTunes?
or does anyone know another solution?
(Sorry for my bad english)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Have you tried DFU mode?
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work try DFU Mode as a last resort. Placing your iPhone into DFU Mode means it does not load the OS before attempting the restore.
HIH
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,581
