Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
iPad Air 1 Damaged Pads on Logic Board ( Will This Work? )
I have a iPad Air 1 with about 14 pulled pads, here what I have so far. Will this work?
The numbering might be incorrect. If I solder jumpers to these pins will this work? Please correct me if I'm wrong
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
It worked. I did as shown in the pictures I posted. It charges, has sound, syncs, e.g.
Was dit antwoord nuttig?
1 Opmerking:
Yay , good stuff mate glad you got that sorted ;)
door
Het nuttigste antwoord
Not all pads necessarily need to be soldered to test points. Some can have shorter running jumpers from the pad you can see the circuitry traces. The ground pads aren't all required they can be skipped if needed.
Score 2
Yes sir that’ll get you back up and running.
Score 1
Voeg je antwoord toe
Tate A zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 762
