How to clean cd & cassette player
how do you clean a cd and cassette player
Is dit een goede vraag?
For CD player:
Get 99.9% alcohol (not your average 70% alcohol but that will work also) and microfiber cloth. (use cotton swabs as a last resort as they leave fibers)
You must be able to see the laser. Lightly dampen the cloth. Be sure to not have it too wet so that it drips. Clean laser GENTLY! It move up and down and can get damaged with too much PRESSURE!.
or
Try a lens cleaner disc. These discs brush the CD drive lightly, removing dust. In most cases, a cleaner disc is less effective than the methods above, and a low-quality disc could even cause more damage.[8] Try it if nothing else works, or skip to the next step if you're willing to try more complex repairs. Cleaner discs usually run automatically when you insert them, but check the product instructions first.
For Tape Player
Steps
Was dit antwoord nuttig?
There are four methods you can use to clean it: air bulb/compressed air, removing the cover lens, and using a DIY CD cleaner.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,086
