Home button doesn't work when installed in place
So on my iPad Pro, whenever I install the home button with the bracket and everything, it doesn’t work. But when I take both out and click it with my hand manually, then it works. How do I fix that? I thought it was pressure at first but when I install it, it doesn’t matter how hard I press on the bracket, I can’t get it to work. The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
Is dit een goede vraag?
5 opmerkingen
"Doens't work" is a vague description, we need more details: does the home button click when you press it? or it clicks but no response in the system? what about the touch ID?
door Gorilla
Updated! The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
door Taz
@taziamoma That is very odd, I never encountered this issue before, sorry :(
door Gorilla
@sammyz me neither. I'm completely stumped. What do you think it could be?
door Taz
@taziamoma My first thought is the pressure. But since you mentioned that was not the case, I'm baffled as to what the cause may be, let's get some input from @refectio
door Gorilla
