Ga door naar hoofdinhoud
Maytag washing machine won't run high spin cycle
Maytag front load washing machine model YMHWE251YL00
It will not go into the high speed spin at the end of washing leaving the cloths still very wet.
The drum will agitate to wash and will do a low spin but when it should go into high speed spin the drum stops, the pump still runs but nothing else is happening. It has 4(?) different spin speed options and none of them work.
All the wash cycles work, the drum does turn, pump works, hoses are not kinked, drain filter is clean just won’t spin.
I am leaning toward the control board but am wondering if there is anything else I should look at before ordering a $110 part.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Not great on washing machines but this does not sound like the control board to me. I would do a little more research. There is a chance I am wrong but with other features working and the spin being part of the same cycle it would seem there is something stopping the spin….. just guessing could be a power issue or a loose connection from the control board
Was dit antwoord nuttig?
Voeg je antwoord toe
SaskClay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,313
