Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
I'm scared to turn on my iPhone
I dropped my phone in my bathtub earlier and I got scared. I opened it up and used the cool setting on my hairdryer to dry the phone and its hardware and everything. I put it all back together and Now the screen wont go all the way in and I’m scared That i’ve accidentally punctured my battery. Its all in place but I’m scared to turn my phone on. Should I turn it on or not? what would you recommend?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hello,
I am understand that your feeling so don’t be panic just clean your phone internally means If your handset has a resemble battery, similarly your phone has some kind of port cover or even a removal back panel, open it up to let your handset air out,
Don not dry your phone with a blow drier because the heat from the drier could damage your handset internally components permanently.
After the clean out your device cleaner (liquid) after that on the phone and check it. But you will be this work quickly,
Was dit antwoord nuttig?
Hi Vidhi,
I can totally sympathize with you here - a punctured lithium ion battery is no joke but signs of swelling are pretty easy to spot
Seating the display bezel in the phone body does require a bit of extra force for it to click into place and for the display to be seated correctly.
Once you’ve given the battery another inspection, try turning the phone on. If the battery is expanding, you’ll be able to see the pressure marks plainly on the LCD. You need to turn the phone on to assess what other damage may have occurred and determine if you are able to repair it.
Voeg je antwoord toe
Vidhi Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 72
