Ga door naar hoofdinhoud
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Vragen Bekijk alle
Touch screen recognizing finger only s pen on note 9
I was replacing a screen on a note 9 and when I switched the motherboard and other components to the new screen and powered it on the phone would not recognize me touching it with my finger so I tried the s pen and it worked fine so then I switched everything back to the old screen thinking that it was just a defective part and it still wasn't working. I tried cleaning off the connectors for the screen and resetting the phone and neither worked. Any help would be greatly appreciated. Thank you in advance.
Is dit een goede vraag?
Score 1
1 Opmerking
I thought so too but I put all the components back onto the original screen and the touchscreen didn't work on there anymore and I also tried different screen and didn't work on there either
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
probably just a faulty screen
S pen is a completely different part of the display to the digitizer, it’s the large rectangle flex near the lcd connector.
unless you buy the screen from samsung or from a new phone they are all refurbished, so probably just a dud screen
Was dit antwoord nuttig?
Score 1
Did you ever get this fix? I'm having the same
1 Opmerking:
Also, would something like that be under warranty?
door
Voeg je antwoord toe
Poop mcgee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 2,301
