Ga door naar hoofdinhoud
The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
4097 Vragen Bekijk alle
iPhone 5s Missing Screws(Got new set of screws)
I have an iPhone 5s which is in bad condition the back cover and the screen. So I already ordered the back cover and the screen replacement. The question is, I noticed that some screws are missing(I ordered also a set of new screws) and I want to put the new ones. How can I find the right screw? There are so many inside the screw set.
Notice: I only need the missing screws(that’s difficult for me
Is dit een goede vraag?
Commentaar:
Can you post some pics of which screws are missing? Someone should be get the specs for you.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can use the following guide to get size and shapes of the screws..be very careful with screen flat cable connectors shield screws as you might damage the board if screws are not of the exact correct lenght. In any case don’t overtighten screws, board is not exposed to pressure, firmly is fine, forcibly is bad !
iPhone 5s Logic Board Replacement
Was dit antwoord nuttig?
Score 3
just leave them out if everything is working. putting the wrong screw in the wrong hole can permanently damage your phone
I am afraid mostly for the 4 screws(top right corner) that holding the lcd flat cables(you know :P) witch one of them in not magnetized or something like that. They say also in some vids that if you don’t put that unmagnetized in it’s hole the compass etc wont work.
I will see how it’s going to be. I hope I remember to leave feedback guys.
Thank you.
Voeg je antwoord toe
KIKO zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 92
