Ga door naar hoofdinhoud
Subaru revealed the third generation Impreza at the New York Auto Show on 2 April 2007—both the standard naturally aspirated Impreza and turbocharged WRX versions were revealed.
3 Vragen Bekijk alle
egr monitor never get ready to pass smog emission
no check engine no codes car runs fine but i need my tags to drive the car but egr monitor never get ready i try many thing even took the car to puente hill subaru and they toll me just drive the car they charge me and they do nothing for me
help what can i do
drive cycle done
replace egr valve done
clean egr passages done
egr vacuum solenoid done
knock senor replace
catalytic replace done
air fuel sensor replace done
disconnect ecm reconnect repeat drive cycle done
2000 miles drove nothing work
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
The egr tube and /or the egr port in the throttle body may be clogged with soot.
Was dit antwoord nuttig?
I would take it to a Subaru performance shop or someone who does ECU tuning. They will be able to program the ECU to run and pass the EGR instantly. Down side probably cost like 400 to 600 bucks. But for that might as well have them tune it so you won’t get a P0420 for a bad cat in the future.
Voeg je antwoord toe
Subaru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 707
