Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
iPad 3 Apple Logo Reboot Loop
Whenever I try to boot up my iPad, the apple logo pops up and then a black screen appears on repeat. I have tried to plug the iPad into iTunes, however the iPad does not boot up, even when holding the power button. It seems the iPad only boots when plugged into the wall charger. If I unplug the wall charger, the screen immediately blacks out.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi! It sounds like you’re having a very similar issue to iPad 3 cycles apple logo when on charger, shuts off when disconnected., perhaps that thread will help you!
A good thing to note is the iPad 3 has a wide range of parts and fix guides you can see by going to its product page.
Was dit antwoord nuttig?
Score 1
That is a symptom of the battery going bad on the iPad. You'll need to get the battery replaced. Might not be worth it as the iPad no longer gets iOS software updates.
Generally for a battery replacement if done yourself it's recommended to get a replacement digitiser in advance as it's very easy to crack it when you need to open it for a battery replacement.
The last version was 9.3.5. The latest one right now is iOS 12.1.2 which is what the iPad Air and newer iPad's support.
Here are links to replacement parts and guides from iFixit:
iPad 3 Wi-Fi Battery Replacement
iPad 3/4 Battery
iPad 3/4 Screen Digitizer
Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad. Afbeelding
Product
$24.99
Replace a battery compatible with 3rd and 4th Gen iPad models A1416, A1430, A1403, A1458, A1459, A1460. Part #616-0593, 616-0592. Battery model A1389. 42.5 Watt Hours (Wh). 3.7 Volts (V). Afbeelding
Product
iPad 3/4 Battery
$39.99
Voeg je antwoord toe
Laurence Lai zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 251
