Can't open my phone
My problem is its been along since I used my iphone 6s plus and I can't open it? What is the main problem of my phone?
Is dit een goede vraag?
What happens when you plug the phone into a charger?
Usually you would see a low battery indicator to indicate battery is flat and is charging after a minute if it hasn't been charged for a long time.
If not see if the charging cable is plugging in fully into the phone.
If you see a noticble gap between the charging cable and the iPhone housing then the charger port may need to be cleaned of dust and lint carefully.
If port looks OK and still does not work try other charging cables and wall chargers.
Otherwise it is usually the charging chip (Tristar) going bad as a symptom of it is the phone can't charge dead flat batteries. You'll need to take the phone to someone that does micro-soldering to get that chip replaced for you.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 176
2 opmerkingen
What do you exactly mean by you can't "open" it Marie ? doesn't it take fingerprint, passcode or... ? Help us help you..
door arbaman
My phone is off so I can't turn on my phone
door Marie Chan
