Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
any reason green lines on MBP display?
my MBP now has a horizontal green streak on the screen - any ideas what that means?
Is dit een goede vraag?
10 opmerkingen
Can you add a picture so we can see Voeg afbeeldingen toe aan een bestaande vraag
door
added pic thanks
door
Do you see this with your desktop being displayed? If you do lets get a picture just to be sure we've got it nailed down.
door
just hooked it up to an external display and no green lines at all
door
What does your internal displays desktop look like? Clean or smeared with red or green? A picture would help!
door
5 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
So we can tell the display its good. If the display its self was bad you would have also seen the line on the white screen or some color distortion on that location.
What you are seeing is noise likely from corrosion on the connector on the logic board or the cable is slightly damaged so one of the lines is touching chassis (ground).
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Dan, thanks so much for the great help. Any ideas on what parts to buy and where to get them?
door
Mostly it's a matter of inspecting the cable for damage, cleaning and refreshing the connector on the logic board (micro soldering). Focus on that first.
door
Your problem my friend is almost certainly a bad display panel. There are a couple of ways to tackle this problem but the most efficient and easiest fix for this is to go over to eBay and pick up a decent used display. You'll find a good selection of them too. Plan on spending between $350 and $400 for the display assembly. The time to complete the swap will vary but you'll probably spend about an hour if it's your first time out.
5 opmerkingen:
With out seeing a picture it could be just a bad iDP (eDP) cable too
door
That's pretty rare. LVDS cables don't just fail unless someone’s been in and out of the machine often. This wasn't mentioned by Sandwah, and he has very little knowledge of the inside of that machine. I'm not dismissing your comment, only that I cannot remember the last time I had the problem with the cable alone.
door
no green streaks after hooking it up to an external monitor, so I assume that means a bad display?
door
@sandwah - Well thats good! So we know the internal display is the focus. Still can't tell if you have a display issue or just a iDP (eDP) cable issue.
Eric, The iDP (eDP) cable issue is not just the cable its self its also the connectors on the logic board or the display. A loose connector or corrosion are a strong possibility.
door
Good catch Dan. Taking the extra time to scope that out certainly can't hurt anything.
door
Voeg je antwoord toe
Sandwah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 712
