Ga door naar hoofdinhoud
The Explorer saw significant exterior, interior, and suspension updates for the 1995 model year, losing all its exterior bodywork shared with the Ford Ranger.
27 Vragen Bekijk alle
Not starting when key is turned to start
Ford explorer has nothing to do with Mac Pro. Im looking for the reason my Ford Exployer just stopped turning on from one minute to the next. Is does not even turn over yet everything else is working but not the ignition
Is dit een goede vraag?
1 Opmerking:
Do you have access to a multimeter? You first need to verify that your battery has 12.6 volts and then I can guide you further
door
Voeg een opmerking toe
1 Antwoord
Ignition switch controls the signal to the computer to power the vehicle and make contact in the starter to engage the solenoid. Otherwise it is your solenoid on you starter
Was dit antwoord nuttig?
Voeg je antwoord toe
Pyasotol zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 95
