Ga door naar hoofdinhoud
A 64.52" LED 2160p 4K UHD Television released in 2015.
11 Vragen Bekijk alle
must power cycle to get pix
VIZIO P702ui-B3 If off for more than a few hours the led (lower left corner) lights, Audio works, but no picture. If power cycled 2 or 3 time it turns on normally.
This happens with the remote or the manual switch on the set.
I’m thinking about replacing the power supply. Could that fix it or perhaps the Tcon board?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had a similar problem with my P55-C1 (audio, no picture). I used a flashlight and discovered that the picture was actually working but the backlights weren’t coming on. I replaced the LED driver boards (four of them) and now I have a working picture again.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
where do you find a driver board? Would you post a tutorial on replacing it please?
door
Voeg je antwoord toe
Greg “Bad Kitty” Arikian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 298
