Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
772 Vragen Bekijk alle
Why does my new logic board only accept OS X Yosemite?
My hard drive uses the MacOS Journaled format.
I put in a new logic board and every time I try to install High Sierra from a USB key , the installation goes as planned until it reboots.
The problem is that the computer keeps rebooting indefinitely after a minute or so.
I used internet recovery and it downloaded Yosemite (!).
I guess it’s a matter of firmware, isn’t it?
But it seems the only way to update the firmware is to install High Sierra, which the logic board doesn’t let me do.
Is there a way I can solve this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Depending on what you had on your system before as well as how you enabled OS recovery you will get the original OS the system had. Pressing Option & and the R keys will get you the highest your system will support
Review this T/N Mac startup key combinations and this T/N How to reinstall macOS from macOS Recovery
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Hi there, thanks for your response. I tried the Option+Command+R but since Sierra was never installed on it, this command doesn't behave the same way.
I still can't boot up, even under Yosemite. It keeps rebooting after a few seconds.
Could it be because there is no battery connected to the logic board?
Or maybe I didn't connect some cable correctly to the logic board?
door
Yes, you need to have all the pieces installed and a working battery ;-}
door
@danj If the High Sierra install put the APFS format on it, it may not accept a lower system.
door
Voeg je antwoord toe
Alex222 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 74
