Ga door naar hoofdinhoud
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
27 Vragen Bekijk alle
Power issues in water heater
I recently replaced my thermostats and elements in my water heater but it's still not functioning properly. Everything is connected the right way but for some reason I have a constant 120v to my lower element and when the thermostat kicks in I get 240v. When the top element kicks in I still have the 120v to lower element. Any fix or test I can do the figure out the problem?
Update (12/29/2018)
It's a Rheem 71 40d b
Is dit een goede vraag?
3 opmerkingen:
What country do you live in?
door
USA.....illinois
door
Hi @tbone42 ,
What make and model are the thermostats?
door
Voeg een opmerking toe
1 Antwoord
The heating elements are wired incorrectly or a thermostat is malfunctioning. It sounds like the bottom element is grounded to the shell somewhere, and whichever power line isn't releasing contact.
This can also happen if one of the power line wires and the neutral wire are crossed.
Was dit antwoord nuttig?
3 opmerkingen:
Heating elements are wired in correctly and the thermostats are both brand new. I also replaced both heating element 6 months ago.
door
The water heater is also 240v so there is no neutral.
door
If you don't have a neutral wire connected to the water heater, something is finding a neutral connection through the plumbing. This can also happen if you're measuring voltage in reference to ground. If an element has 120 vac across it's two terminals, either a thermostat is malfunctioning or something is not right with the wiring.
door
Voeg je antwoord toe
Michael Shayne Bradley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 316
