Ga door naar hoofdinhoud
Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1638 Vragen Bekijk alle
Installed new Samsung SSD but Time Machine can't find destination
Hi all! I installed a new Samsung SSD 860 EVO in my macbook pro and backed up my hard drive to an external drive (both are done). Now I am trying to use Time Machine to restore my computer to the newly installed ssd but when I get to the “Select a Destination” step it says “Searching for disks…” and can’t seem to find anything. Please help!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Did you replace the HD SATA cable? Often times you need to as the original cable is not able to support the higher data flows of the SSD MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable.
You should install the OS onto the new drive first before restoring. Restart your system and hold the Command (⌘)-R keys to get into internet recovery.
References:
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Afbeelding
Product
$34.99
Was dit antwoord nuttig?
Score 2
Re-seat the SATA cable into your SSD. Have you confirmed this SSD is functional by using it in an external enclosure or HD dock?
Score 1
Voeg je antwoord toe
Eric Kelly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,018
