Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
213 Vragen Bekijk alle
Ipad Air 2 touch ID not working after screen change
Hi all,
Changed the screen on a ipad air 2, which you need to remove the touch id home button & flex from the old/damaged screen to place on the new, but after doing so the touch id no longer works, I have double checked the connectors, flex etc and see no signs of any damage so not sure what else to check.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Have you tried it with the original screen to see if it works?
Was dit antwoord nuttig?
Unfortunately the most likely situation with this iPad is that the home button was damaged when it was removed from the original screen, and this cannot be repaired. If it does not work as a home button you can either replace it or use the 5 finger gestures.
iPad Air 2 Home Button and Gasket Assembly
iPad Air 2 Home Button and Gasket Assembly Afbeelding
Product
$19.99
1 Opmerking:
Note, the replacement button will only act as a home button, not touchID
door
Voeg je antwoord toe
colin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 415
