Will not boot up or charge
iPhone 5 has been turning off & on by itself for a couple of weeks, but it could still be turned on with power button on top & was charging & working fine.
Now it won’t turn on & when put on charger, the white apple boot up screen turns on then off, in an endless loop.
Is dit een goede vraag?
it sounds like a dying battery, but you say it was charging and working fine? was it taking longer to charge or needing to charge more often? I would also look at trying a different charger to make sure that's not the problem. Check the dock connector for dust/lint. Use a wall charger and leave for 1 hour.
door pollytintop
