Faulty iMac - Only three LEDs appearing in diagnotics?
Hello iFixit users,
This is an incredible website, and it seems like many users have benefitted from suggestions made by others.
I'm experiencing an issue from an iMac I had willingly bought as a faulty machine. At the time of the machine's sale the seller experienced an intermittent problem with the iMac only sometimes working for days at a time. There would be intervals of time when the iMac would otherwise not boot for a few days.
Removing the iMac's glass screen and front shell, I can see the LED's and cabling clearly.
Only the first three of four LED lights are lit when the machine is powered on. Upon pressing the power button, the hard drive, superdrive and fans will kick into action for 8 seconds, then the machine will turn off and turn on again. This time the machine will simply hang in a constant state leaving the hard drive, superdrive and fans spinning.
I understand that the absence of the fourth LED light leads to indicate that the LCD could be faulty, that the LCD screen cabling may be faulty, or that the logic board itself may be faulty too.
The machine does not chime, neither does the LCD screen come to light or keyboard/mouse seem to be responsive in resetting PRAM or booting with Target Disk Mode or boot-from-CD.
Would anyone suggest I double-check the PSU with a voltimeter, or single out any other components before I resort to the problem being a fault of the logic board?
Is dit een goede vraag?
5 opmerkingen
+ Well stated question
door mayer
Andrew,
I know its been a long time since this post has been written, but I have come across the same findings.
When I removed my video card and installed the logic board back and fired the machine up, 3 LEDS still lit up claiming that it found communication with the video card.
I was wondering whether or not you have found the answer to this problem or not.
PLEASE LET ME KNOW
door Akis P
Hey Akis P, thanks for writing!
I didn't find any fixes for this repair unfortunately. I sold the iMac on as I couldn't find a decisive answer.
Good luck!
Andrew.
door Andrew Strugnell
Thanks for replying I narrowed it down to either the logic board or graphics card.
I'm 50/50 on which one there is since there is no exclusive test to rule one out. Because from what I'm told apple techs just swap parts to confirm the problematic part. And since I don't have that kind of parts inventory at the tip of my fingers. I will probably purchase a known used graphics card first and hope that fixes it. Since the card is way way WAY cheaper than the board.
door Akis P
Your problem sounds the same as mine - posted here: iMac won't start after HDD replacement - no chime, black screen, DVD
It only happened to me after replacing the HDD so I must have broken something while doing it.
I'd be interested to know how you get on- does replacing the Video Card fix it?
Also what is the model number for the video card, where did you buy it?
door rhubarb
