Ga door naar hoofdinhoud
Een gameconsole voor de televisie, geproduceerd door Sony Computer Entertainment, ook bekend als de PS4. Voor het eerst aangekondigd op 20 februari 2013 en gelanceerd op 15 november, 2013.
1695 Vragen Bekijk alle
My playstation turns on, it beeps and the light appears then its off
it turns on for like a second then turns right off then you cant turn it on again unless you turn the power off at the wall and press the ps button on your controller.
please help
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Kris. Does the Console have any notable history of drops or of water damage? Are the vents filled with particularly heavy deposits of dust? Any of these answers may point closer to a solution, but PS4 repair can be pretty open-ended if the cause is unknown.
If you have hours, and I mean many hours of spare time and would like to troubleshoot this yourself, I recommend watching some of the PS4 YouTube videos by Andrew Paul. You will also need to get yourself a set of security torx screwdrivers to even begin any PS4 disassembly.
It definitely is worth testing a new power supply on your console, if only because so few screws are required to swap the PSU and you don't have to take out the motherboard to get to it. The power supply is not *very likely* though. A dead power supply would mean no light and no beep. So in your case, it could be a failing power supply. Maybe you can purchase a new PSU from a seller with a good return policy…
In my experience, consoles like yours usually have a complex motherboard problem. However that's where 50 hours of free Andrew Paul videos come in handy!
If you don't want to deal with this yourself, call around to the local computer repair shops and cell phone repair shops specificly asking if they work on a lot of PS4's. You don't want someone with no experience simply taking a heat gun to the motherboard “because they saw it in a video". That type of troubleshooting can only make a board unrepairable. In most cities, the CPR Cell Phone Repair franchises either fix PlayStation 4 in house, or they escalate the ticket and ship them in to CPR corperate.
Just keep in mind a few things: you can go on OfferUp or Letgo to buy a used PS4 for only $150-200 if repair is too much trouble. If repair is too costly, you may be able to sell your dead PS4 to the shop for $25-$50. If the motherboard really is dead, don't expect a shop to offer you a lot of cash for the box. It may have a lot of $50 parts inside, but they have no way of knowing the history or condition of those parts or if they will actually need them in the future. Take whatever cash you can get if it really isn't fixable.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
it's cheaper buying a new one rather than fixing it
the labor costs more than the parts are actually worth
costs around $300-$400 getting it fixed
door
thank you for your help, greatly appretiated
door
try to find out whats wrong with it and get that fixed
Voeg je antwoord toe
kris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 412
