Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
434 Vragen Bekijk alle
Can't erase disk, nothing is working
I have a computer that I securely erased the SSD with Parted Magic.
I booted to the Mojave installer and went to diskutil to erase (reformat) the drive to prep for install. The SSD was not showing up.
So I went into the terminal and found the SSD via command “diskutil list”, it appeared at the bottom of the list as disk20, which I thought was weird because it is generally disk0.
I used terminal to erase the SSD for install: “diskutil eraseDisk JHFS+ Macintosh\ HD disk20”
The process got stuck on erasing at 50% and did this for a whole day.
I am very confused, at this point I’ve tried:
·         Using different bootable installer (high sierra, sierra, elcap)
·         SMC and PRAM resets
·         removing battery
·         using a different SSD (…so it is the computer not the drive)
·         And simply just trying multiple times
I am at a loss, any ideas guys?
Thanks in advance for the help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Does Parted Magic format APFS? Why did you use it instead of Apples Disk Utility? Why the secure erase?
Was dit antwoord nuttig?
Commentaar:
Parted magic formats the drive to NTFS, but I have never ran into this issue using Parted magic.
I always just reformat the drive back to APFS or JHFS.
The reason I use Parted Magic is because I work in a facility where data security is our number one priority.
We fix University machines and sell them to the public.
Apples disk utility doesn't actually securly erase SSD's.
door
Since you're a Professional, I would invest (and I have) in all the different OWC Envoy external enclosures, so you can work with these Apple SSD blades. Try this one: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Enclosure for Apple Flash SSDs, (OWCMAU3ENPRPCI) https://www.amazon.com/OWC-Portable-Bus-...
I get them cheaper because I order them with the upgrades.
door
I do have something similar to this, for most of apples funky proprietary SSD's.
I usually have trouble booting parted magic on MacBook’s while trying to erase the drive in the machine, so I usually pull them, use the adapter, and wipe them in a PC.
I forgot to mention that I did this for both SSD's I tried in this machine.
Not really sure what the heck is going on here!
door
Voeg je antwoord toe
Taylor Struna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 68
