Ga door naar hoofdinhoud
Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
Is dit een goede vraag?
4 opmerkingen:
Is your amp repaired??
door
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
door
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
door
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
door
Voeg een opmerking toe
1 Antwoord
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
Was dit antwoord nuttig?
1 Opmerking:
I am unable to upload images but its peavey cs 2000 power amplifier
door
Voeg je antwoord toe
daniel mucheke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 2,062
